apexi turbo timer install... need small help
myeclipseisnice
381
Sep 2, 2003
south river, New Jersey
ok so i have the apexi turbo timer with the harness...
ok the two 6 pins connector from the harness is connected...
then its connected to the turbo timer itself.
now the turbo timer has the gray white and black wire... i put the black to ground... white to the ecu 02 sensor, and gray to the e-brake...
i think im done now and it will work fine... but i do have an aftermarket alarm (viper) and also the stock alarm still works as well...
am i done with the installation or is there something else i need to do since i have my alarm working.??? i searched and searched and i cant find a install with an aftermarket alarm... i even checked out the vfaq but there install is with a stock alarm system..
thanks in advance
i just installed a Aepxi turbo timer and i have the stock alarm on my 1997 GST and and every time the turbo timer shuts off like 10 sec. later the car turns back on??? why is that?? i have installed the the harness and the gray wire to hte e-brake and the white to the 02 by the ECU and the black to the ground. so everything is install but it kepts doing that and i dont know why??? some one help me please!!!!!!
:dsm:
the turbo timer should work fine if installed correctly. however, your alarm wont work while the car is running.(timer counting down) you have to install a relay on your alarm. i found it on a yahoo search but never did it.
ok this may be a stupid ? but where is the ecu on my car and what color wires do i conect my gray and white wires from the tt?
The ecu is behind the radio. You can take the kick panel off right drivers side and it will be right there. As far ase what wires you need the tt should have came with the pin locator page if not let me know I think I still have mine.
