apexi avcr
rkn527
64
May 9, 2004
capitol heights, Maryland
i have just purchased a apexu avcr electrical boost controller and i would like to know there is a t type of sensor what vaccum lines goes where and what runs to the to the wastegate
not to seem rude but, can you make more sense with your question? I'd like to help you. Are you looking for a sensor???? or are you looking for a vac/boost line to tee the AVC-R solenoids into????
If you have everything in the AVCR kit you just need to set up the main AVCR interface and run the solenoid between the BOV line and WG actuator line.
the solenoids will be located in place of the MBC
goodluck!
solid
i would like to know what vaccum lines goes to the turbo sensor and what goes to the wastegate i have an external wastegate
rkn527, please use capitalization and proper punctuation marks in your future posts, guarantee to net more respones and won't get your thread closed. :thumb: I don't have an avcr so I'll leave that to someone else.
oh ok thanks for the replys but from what i was told i should use the same line that goes to the bov and put that on the side nipple of the boost controller unit.the line that goes to the wastegate will go from the front of the boost controller unit and it will run to the the side opf the wastegate. if that is correct what setting should i use to as a stock setting then i can work from there
