apexi AVC question
eclipse boi
Dec 15, 2005
austin, Texas
i have an AVC-r on my 96 eclipse gst. well i saw an article on a supra website how to more less tune the avc-r and basically it was the boost duty cycle percentage that determined the boost levels. Well no matter where i set the boost duty cycle the autometer boost gauge reads 9-10 on the gauge, is it like a bad boost solenoid ?? ive also been reading alot of articles about boost on here and, if the gauge reads 9-10, is that actually 9-10 psi ?? anything is much appreciated:thumb:
It saounds like the gauge is reading right. My question is want are you looking for in boost duty cycle. If your saying no matter where you set it it goes to 9 or 10 psi something is wrong. That is stock boost. Do you have any after market fuel parts or is everything stock. I want to know do you have a boost controller?
well from what i was told it will only go up to stock boost if the lines are not right. i have the avcr on my talon and the same lines that goes from the intake to the bov u need to tee into that and put it to the side of the boost pressure valve and the from port on the valve go directly to the wastegate on the side port
the gauge is fine. im talking about my avc. I cant get the avc to raise the boost on the car. no matter how far i turn the avc up, i doesnt turn the gauge past 9-10.
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
