Anyone Rust protected with VHT?
all rust converters are based on phosphoric acid - the same thing that is in Coke.
I do not see any advantage to this stuff over the quart jugs of rust converter that you can buy a advance for about $6. With the liquid stuff, I used a small plastic container pour about 1/8 of an inch in it and treat the heads of my bolts. Black looks better than rust any day.
I did find this that "sounded good" but I have not tried it.:
Stop the Rust | Rust Bullet, LLC
sounds like he had "Extend" Ya all of this stuff is better than nothing.
It's a toss up, the spray is easier to use, but the jugs at advance go a lot further.
If you are going to treat with parts on car, spray it. If you can take them off, sand them, soak them in phosphoric acid and then paint them.
The donor car I used for awd conversion was a rust bucket, the rear carrier was solid rust. I wire brushed it, brushed on the jug stuff from advance, and then painted it with rustoleum. so far only one small spot has popped out.
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
