Anyone running CFDF Pressure Plate with non-CFDF clutch disk?
bvass
447
4
Apr 23, 2006
Mesa, Arizona
My Center Force Dual Friction clutch has been great for a couple of years but now that i moved to a bigger turbo and started making more power it started to slip after a couple of hard launches (1 hour cool down time between launches). I am thinking of resurfacing the pressure plate and flywheel and going with a different clutch disk. Has anyone tried that before? Can you please specify witch disk you used and how much torque you were making?
I am hoping to put together a combo that can hold 450 ft/lbs of torque and take more hard launches at the track.
I know it has been done before, recall a guy on DSMTalk with the CF DFX PP which as far as I know is basically the same as the DF & I believe he used it with an ACT sprung 6 puck. Last I heard, he was happy with the setup.
You use to be able to run the CFDF pp with the ACT discs, but last I heard the new design of the ACT discs dont fit with the CF pressure plate.
But for confirmation, I ran a CFDF pp with an old ACT street disc.
It did not hold it for long, after 5k miles and about 3 lauches it gave up. It still held the roll ons but as soon as I put some heat in it she started slipping. I went to the twin disc after that.
This is what happening to my clutch right now. I would guesstimate that I am putting out around 400-450 ft/lbs of torque and after my third launch the clutch started to slip. I waited an hour between launches to give it time to cool off. Did you see any improvement after going to the Kevlar disc over the CF clutch disc?
I never ran this motor with a CFDF clutch. Just the CF pressure plate I had laying around. It was just a band aid until I got the twin disc. The Kevlar is good until it heats up then it needs to cool down to work again. But unlike a standard fiber clutch it is still good to go after that. If you burn up a standard fiber clutch it is pretty much shot after that, it won't quite have the tq holding ability like it used to. The setup was just a little too soft for my power & torque. A better pp would have been something 2600 lbs and up. I forget what the CFDF plate is rated at but I think it is near the 2300lb mark.
As far as I know RRE tested the CFDF PP to 2500 lbs which puts it very close to the ACT2600. The reason I want to go with CF PP is that it has a very soft pedal feel and it does not put as much load on the crank as the 2600.
