Anyone do a head gasket like this?
bcjjones
509
6
Nov 3, 2011
Austin, Texas
So I spent some time doing a head gasket on my gvr4. Being a husband, full/overtime worker and father to a two year old I don't have much spare time. Did most of the work was done after dark in the street with very little light. I must have scratched the gasket when putting the head on. It's leaking oil from the head gasket right in the middle by the middle front oil drain in the head. I was hoping it was just the stud for the exhaust mani but unfortunately it's not.
It's a rebuilt head and the block was checked for warping.
Has anyone just lifted the head, pulled the hold gasket out and slipped a new one in? Was gunna have a buddy just hold it up while I did a quick swap..I just don't have the time to do it all over again. I'm using head bolts and not studs.
Good or bad idea?
As long as you have proper lighting to see everything you're doing and make sure you don't damage the gasket or the head, you should be good to go.
I did the very same thing on a 318i bmw.
If you are sure the head is flat, go for it. But I wouldn't recommend reusing the head bolts, since they're tty.
I just went ahead and removed the head, I sure did scratch head gasket prettt good. Got it off in 45 min!
Thanks for the help!
Good deal, 45 minutes? Wow, it takes me 8 hours.
