Woodsy0
- 177
- 2
- Apr 1, 2004
Lexington,
Massachusetts
I just bought Koni yellows and H&R O.E. Sports, and I'm having a hard time figuring out how the Koni's are assembled in terms of all the small stuff that goes onto the shock shaft (collar, bushings, washers, bump stops, etc). Maybe I'm just not a visual learner, but the directions that Koni provided were confusing as hell. To add to the problem, I ditched my OEM strut assembly long ago, so I don't know which OEM parts I will need to grab, since Koni requres the re-use of certain strut parts. If someone can provide a listing of which OEM parts I need to reuse, as well as the order of assembly onto the shock shaft, it would be very appreciated. As of now, I have the OEM upper mounts, OEM metal collars, new OEM bump stops, OEM "cups" (metal cups, look like they fit over the bump stops, got them new per the exploded assembly I saw on Mitsubishiparts.com), the two rubber bushings per shock, and the upper shock mounts. Koni came with a bunch of small washers and assorted shock parts as well, and I'm no sure how they all go on/in what order.
Also, this might be a dumb question, but did the OEM shocks come with dust covers, and do the Koni's necessitate the reuse of these? I don't remember if they did, and the diagram on the Mitsu parts site didn't indicate a dust cover, but the (generic) directions that came with the Koni shock indicated the use of a dust cover...
Also, one last thing, do I need to trim the bumpstops given the lower springs and different shock damping characteristics? If so, how much?
Thanks for any help anyone can give,
Scott
Scott
