2G Another wheel question....dont shoot me
Chris Diehl
May 18, 2019
Bonaire, Georgia
97 eagle talon esi with stock rims/hubcaps and factory ride height. Were wanting new rims and tires. Something to either completely fill up the wheel well or leave an inch or 2 so it can be lowered. We dont want the tires sticking out at all. Flush would be perfect. I dont know anything about rims and tires other than they're very necessary . I'm an old dude and this is my sons car. So no gap in the wheel well and tires not sticking out. What size and offset.
One of the perfect combinations is a 17" wheel, 8" wide and an offset anywhere bettween +38 to +42. A 225 tire on that wheel will poke slightly but if you got with a 215 it should be fine. So a 215/50/17 will give the car a great look while filling up a lot of the gap, but also leaving room for a standard lowering of 1-2".
.....Something to either completely fill up the wheel well or leave an inch or 2 so it can be lowered. ......So no gap in the wheel well and tires not sticking out. What size and offset.
Wheel gap can't really be changed without lowering the ride height of the car, -using a much taller tire to fill the space is not the best solution. A taller tire increases drivetrain stress, decreases torque to the ground and causes a percentage of error in the speedometer for street driven cars.
An 8" wide wheel with a +38mm offset is just about flush wearing a 235 width tire.
https://www.dsmtuners.com/threads/will-these-wheels-tires-fit.286685/
