And so it begins.
got_no_sol
295
Jun 20, 2004
everett, Washington
Copying for another forum, so don't mind the breaks :p
Had the car since tuesday, and have a couple days off, so figured it's way overdue for a system :p
Plenty o' pics -
Before, after I removed the spare and rear washer reservoir -
After airsaw and hammer -
Pre-glass, test fitting amp and building frame for box -
Action shot, was really wishing I had a respirator about this point -
After 2, 3 or 4 layers of glass -
That's it for today. Ran out of time, and was rather high.
So. Here's what we got done today -
Glassed the outside box edges and did another couple layers on the inside. Box is solid.
Unfortunately I didn't get any pictures of the final box assembly, but it was pretty straight forward. Pre drilled all my holes and silicone sealed the edges. Bought some 1/4" foam to go between the box and the floor so it wouldn't rattle. Spray adhesive worked wonders with this stuff.
Test fitting -
Oh, painted the interfooler today too :p
Sub amp mounted, don't mind that the amp is "upside down" as there will be another amp mounted on top. Unfortunately the sub amp rca's weren't long enough =(
What it will look like once it's all done.
Going to make a false floor with an integrated grill and use security screws to help deter thieves.
Probably won't have much progress til next weekend though. :|
And btw, it wasn't me who put the dynamat on the plastic panels, it was the previous owner.
Sounds good man. Amazing what 1000rms to a single 10 will do :p
