Alternator Belts
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
My alternator belts keep getting tore up. I replaced it 3 times and the last one is not even on there anymore. Whats causing this.
make sure the alternator pulley is not moving, make sure the water pump pulley isnt moving (ie. lose bolts or the actual water pump shaft is messed up). Other than that...make sure nothing is hitting the belt.
One of those should fix the problem.
