alternative differential options
fisher83
89
Aug 23, 2013
Tacoma, Washington
So this is going to sound a little ridiculous, but bear with me.....in the mid 90s dodge/Chrysler caravans had an awd option. Was their rear diff supplied fron mitsubishi? I ask this only because they are usually cheap cars to buy, found in junk yard every where and if that rear diff is a feasable option then that would be a good place for replacement diffs for those of us on a budget? I suppose the transfercase could be viable as well.....anyone ever looked into this?:confused:
If the chrysler 3.3l v6 awd transmission matched up to the 420a, then in theory you could make an awd 420a? Im going to do some more research.
so I did some research, and found the chrysler used the A604 trans which had three sub models: fwd 40TE, 41TE and the AWD 41AE. they used them on 2.2L, 2.5L, 3.0L (6g72), 3.3L and 3.8L. Some versions were driverside mounted transaxel and t-case. Possible option for n/a guys who go turbo?
