alignment readings...
blcknspo0ln
DSM Wiseman
7,773
95
Jul 31, 2003
Central, New Jersey
so i went to readington auto and tire to get my car aligned. I just received a call from them and they said that my car is out of whack ... WTF!? i just lowered her with tokico shock/springs and it shouldn't have lowered it more than 1.5".
he told me that the castor head couldn't sweep and take a reading for my front tires and they couldn't adjust anything... the only thing they got done was the rear's and he said that both rear's were off about 1 degree, which isn't too bad.
I dont feel like buying tires every 10k miles, what can I do now?
hmmm here are the printouts: the only thing i can decipher as off is the front camber...
left front:
camber : -1.7*
toe : 0.00
right front:
camber: -1.3*
toe: 0.00
front:
cross camber : -.4*
total toe: 0.00
set back: -0.01
left rear:
camber: -0.8*
toe: 0.05
right rear:
camber: -0.7*
toe: 0.06
rear:
total toe: 0.10
thrust angle: -0.01
That's darned near perfect for a street DSM. What are you bitching about?
- Jtoby
Not if you like turning. Having about 1.5* front camber with .75* in the rear will help with the inherent understeer. You also have zero front toe, so the 1.5* of camber won't cause any above-average tire wear; the rear toe-in will keep the car stable, especially under hard braking. Slap some RM sways on it (if you haven't already) - or maybe just the rear bar, to loosen the car up some more - and have fun.
- Jtoby
  • For sale 1g Oil return mhi
    1g oil returns
    • 92AWDHX40
  • For sale 2g awd rear hubs
    2g awd rear hubs with arp extended studs.
    • jweber
  • For sale 2ga Auto vss NOS
    2ga auto vss sensor and and driven gear. New old stock
    • jweber
  • For sale 4G63 Dynatek Arc-2 brackets
    Dynatek Arc-2 brackets. Were originally for mounting the box on an Evo. Stainless. One has...
  • For sale Evo3 16G
    Bought this from a member here. Used it for about 150 miles then swapped it out for a more...
    • silentsnow31802
