AGX's causing wheelhop?
DaveDSM
294
Mar 12, 2003
I recently autoxed my awd talon. my setup has agx shocks/struts with suspension technique springs, and ES bushings on the stock rear swaybar endlinks. I set the rear AGX's to 8/8, and the fronts to 3/4. During sharp turns the rear of the car would wheelhop while i tried to put power down exiting a sweeper, and a hard right turn. What on the 1g rear suspension would cause wheelhop? Could the rear shocks be blown? They do get stiffer as the settings increase..although it seems that the whole body bounces as well..
im not sure about rear wheelhop with a awd but ive heard its not good to have it at the stiffest setting it will prematurely wear the shocks i suppose you could have a blown a rear shock i have the same shocks in a 2gnt and havnt ever stiffend them all the way due to reveiws of the short life of stiff settings.-matt
It's hopping cause those shocks are too stiff at 8. Set the rear's to 5 and work your way from there, hope that helps. Cross your fingers & prey that it's not your transfer case or rear diff locking up...
Saber!...!...!
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
