AGX adjustable struts...
1glaserturbo
591
3
Feb 12, 2005
Creve Coeur, Missouri
I recently purchased a barely used (3 miles) set of AGX adjustable struts for all four corners, and it seems the front struts don't have the adjustable knob. There is the threaded hole for the brake line bracket, and on the opposite side there is a threaded stud that is about an inch or so long. Could that be where the knob goes, or are the front struts a different setup although they say AGX??
Chris:laser:
Edit: Haha, was just informed that the adjustments are on the TOP of the front struts, go figure :D
The front struts are adjustable from the top. There are four settings that can be adjusted with a small flat tip screw driver. With the screw driver push down and turn to the right 1=firmer 4=firmer.
It took me forever to find this......thats what happens when your GF works on friday night ROFL Anyways here it is.....
