Aftermarket Tubo Manifold doesnt line up with stock
ripcity
Jul 17, 2011
White Salmon, Washington
Hey guys I searched and did not find what I was looking for, My problem is that I bought a Turbo manifold from a guy who has a 92 talon, when i went to install the mani everything lined up except for the bottom farthest right and farthest left studs that stick out of the head so then I took my stock mani and lined it up and the holes are off and this totally dumbfounded me, so i guess my question is why are my studs in different places and should i just drill the mani to fit?
Its most likely a cheap ebay like manifold. Cost is cheap and fitment as well as the life of it is poor. Post a picture of the entire manifold so we can verify what it is. If your not worried about what it is drill the holes out like you mentioned.
i think what boston is talking about is exactly whats going on its the bolt thats near the power steering bracket that wont fit on i thought they were supposed to be the same too but i guess not everything can be perfect
Its both bolt holes that are off but just one that doesnt fit when you actually try to install the one closest to the power steering bracket, i tried the mani the gasket im re using because its a 2 layer metal gasket thats about a month old
I had the same problem with mine. I took a grinder and took off enough for it to fit and worked fine. Took 20 minutes
i have an evo eight mani on my 1g head just drill the holes out a little or slot them with a die grinder they are not that far off from each other and the flange on that manifold looks thick enough to handle a little material gone hope this helps:thumb:
