AFRs staying at 10.2??
BoostBuddyGSX
75
Oct 7, 2009
Central, New Jersey
So.... at WOT between 3 and 7k, my AFRs are pinned at 10.2. Weird??:confused:Or normal..? I set my boost level at 19psi and at WOT I was hitting fuel cut!! so i turned it down 1psi and i set my corr. value on my S-AFC to +20% from 4 to 7k and its not happening anymore...for now... Also, I'm bogging at throttle release. I'm thinking maybe the MAF? any ideas on whats going on guys??
700cc injectors on a SAFC ?? isn't the maximum 650cc or something for safc..
nothing wrong with low 10 afrs.. its safe....
and your hitting fuel cut because you have it set to +20 ....
setting to 0 or -10 for starters and see if you still get fuel cut...
i had it at +0% corr. value at 19psi and it hit fuel cut. 18psi and +20% corr. value stopped it. and yea, i bought the injectors used, and the guy told me they were 700cc... i was too excited to stick 'em in that i didnt check part #s and such..
like the post above me... yeah you adding 20% with 700cc will make you hit fuel cut sooner... you are suppose to already start by doing the base compensation for those injectors .. they 55% bigger than stock... but the afc only does +- 50 ... thats why you dont want to use fuel injectors over 650cc ..... and with you having to -50 ... imagine the timing curve..
I am also curious as to why my WOT AFR is a CONSISTENT and unchanging 10.2. There is never a deviation from that number, even with the following:
-different RPM ranges
-different boost levels (tried 10-20 psi)
-different gears
-different loads
I know that that the computer cannot so instantaneously adjust to keep the WOT AFR at 10.2. I also know that I shouldn't be able to maintain that AFR at 20psi as with 10psi, without any fuel modifications. And I know that it can never be so dang spot on consistent and unchanging with the above mentioned varying conditions.
So what's going on?
My AEM wideband is brand new and I get no error lights with it. The idle and cruising AFR's are stoichiometric, and it reads full lean during deceleration, so it's reading properly.
  • Wanted 6 bolt NT water pipe
    • chrisman287
