AFC vs AFCII
killab443
602
3
Nov 24, 2003
Howell, New Jersey
Is it worth it to get the AFCII over the AFCI. I found an afc for 150 and an afcII for 200. is it worth the 50 dollarS to go for the II? whats the pros an cons
its all personal preferance. The afc2 has more rpm input points on one other feature I forgot that the afc doesn't have. I prefer the afc because I is easier to use, the knob on the afc2 makes It bit tricky to tune while the car is moving.
98eclipseRS said:
...the knob on the afc2 makes It bit tricky to tune while the car is moving.
That's cause you're not suppose to be tuning, you're suppose to be watching the road :thumb:
SAFC-II also lets you save two tunes. So, you can have one tune for pump gas at x PSI and another for race gas at y PSI.
