AF/X CPU Vs. GReddy E-management
lawdaman
208
Sep 22, 2003
Miami, Florida
I know the GReddy E-Management is nothing more than a tunable piggy-back set up that allows you to adjust your factory settings to your needs and the A F/X CPU is a complete replacement that can adapt to the changes you make to your cars performance, among other things. I'm planning on turbocharging my RS either through a STAR or custom set up, and would like know which would be more beneficial to my needs, seeing as I'll need to access to my fuel:air to get the most from my car. Or can I use both? :confused:
You can... the advanced timing would help on the low end (and spooling the turbo), you would just have to get like a crane ignition system to retard the timing back down for when the turbo is spooled. So really, you'd be spending the money on the af/x ecu just to get that extra push from 1k-2.5k
I wouldn't recommend it unless you really know what you're doing or have alot of money to blow for when you mess it up.
