2G Aeromotive afpr return fitting
Jacolu3
638
131
Jan 31, 2015
Lake Grove, New York
I purchased an aeromotive afpr with all the lines. They all are 8-an for the feed and return.
My problem is the return nipple is much bigger than the return hose size. It was working for a while but started to leak. So I ordered a 6-an barb to 7mm which does not work because the return on this afpr is 8-an. I can not find a 8-an to 7mm barb anywhere.
I am just using a rubber fuel hose for the return. Anyone have any suggestions?
Thanks
Brian
Did you get one of the X1 series regulators? what size is your return hose? if your running a 8AN feed, you should have a 6AN return. Cant you just swap the outlet fitting for this one and run a 6AN return if your not already?
All of the inlets are 8AN. For the feed and the return
I'll have to find a link for the one that I bought
