Aeromotive 340 pressure release valve
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
Does this pump need to have the relief valve punched so it doesn't release under high pressure?
I run the Aeromotive 340 intank pump and didn't punch mine out. I am a 2.0 with 1650's and a HX40 on stock lines and have not had a problem. I do admit I may be pushing the limit in more than one area but so far it's all good. Just from a fellow user.
I didn't punch mine, currently just a stock rebuilt 2.0, 14b with bolt ons and v3, so nothing crazy. Future will be a holset to start, then more.
I know ppl do it with walbros but im not sure it's needed with the 340.
Highest I've hit is 22lbs/boost, so 59lbs fuel pressure so far, no issues with fuel as far as ive seen. I'm going to be pushing it more this year hopefully, and Im also going to get a fuel pressure sensor so I can actually log it in link.
I think @GST with PSI could give you more info on what the pump can handle, IIRC he was/is using one on his galant.
