Advice needed for 2G Stock BOV upgrade (vent into intake)
Brandywine_GST
Feb 15, 2010
Budapest, Europe
Hi guys,
Alright, I'm all new to the DSM scene, but did read about the stock 2G BOV that it's basically a piece of plastic and can easily leak, and should be changed.
I would like to change/upgrade it to a BOV, which is recirculated just like the original one and vents into the intake. MAS system is stock, so I need something that won't confuses the MAS.
I don't need the fancy "psssshhhhh" sound, just would like to upgrade to a better BOV.
Any advice/recommendations for such BOV? Other than a crushed 1G BOV, please.
Thanks guys.
I agree with the 1G valve. Either that or a Greddy RS with the recirc fitting, which is what I have on my car. Do not use a generic Ebay one or a Blitz, I had a Blitz (came with the car) and it started to leak boost at 7 PSI. And I've seen a couple ebay ones that just wont open at all at lower pressure, bad for the turbo.
I put a 1g uncrushed on my 2g, works great! All you will need is the flange from a 1g and a small piece of pipe welded to the bottom of the flange.
Just about any BOV will be better than the stock 2g BOV. If you haven't upgraded to hard pipes it would be a good time to do it as well and get a pipe that is flanged for the BOV you wish to run.
