adjusting idle screw and running too rich..
reddsm00
235
Jul 19, 2004
east brunswick, New Jersey
hey, im having a problem with a really high idle...the car usually idles at 1200 to sometimes 1500 rpm and if im driving and i go into nutral the idle will not stop bouncing up and down until i come to a stop...then after about 10-15 seconds if im sitting at idle it will drop up and down again until i start moving...i was just wondering how to adjust the idle screw the right way...also im having a problem with running to rich, i installed a dejon tool air intake but i left the airbox off...could this be the problem? would putting the airbox back on fix it?
not a mechanic, but try making sure that your fuel filter is clean, fuel pump is wired correctly, and any other maitenance issues are done, then you can change the Idle Speed Controller. I think the best way to change your idle is to have a mechanic change the voltage in the ISC rather then turning the screw.
  • Wanted 6 bolt NT water pipe
    • chrisman287
