actuator and mbc help
GS-T_racer
Mar 26, 2003
Fontana,
I was wondering what would be the gains if i were to get the fp actuator and a joe p mbc? Would my car still run right? Right now im pretty much stock but, i've done ll the free mods, tt, boost gauge, k&n fipk, greddy type-s, ucip, and a 2.5 cat-back with stock cat :cry: :mad: :barf:
Any help or opinions would be apreciated Thanks. :thumb:
dont really have that much money to spend
The FP product will allow you to run 15psi and hold till redline. So when you increase the boost with the joe.P you upgraded actuator will let you hold that psi longer. Yes your car will still run right
If your talking about the upgraded FP 17lb wastegate actuator, for the FP Big28, it is pre-set to 17lbs, therefore you will not be able to run any lower than 17psi of boost. I have the 17lb acutator on my FP Big28 and it helps tremendously, although I do run 20psi daily with supporting mods. But... to answer your question, yes your car should run right. Just make sure that you have your fuel system upgraded if your going to run 17psi or more.
