ACT2100 slips a little what RPM 2 launch at
If your clutch has less than 80k rev it up to 5K and dump the clutch on awd .will get at least 1.8 60'
Pretty well what bestsitu said. I pull 1.717 with my 2100 and went 12.13 @ 113mph this weekend. It has around 50 passes at the track on it as well... I blaze all 4 tires though 1st gear with no clutch slippage. I use a MSD DIS2 with the studder box at 5500rpm and pretty well just drop the hammer on it and go...
Replace the clutch line with a SS one and the slipping will go away when you launch and between fast shifts. I couldn't get lower than a 2.0 60 before I did mine now I'm doing consistent 1.8's and I suck at driving.
Ah,yeah. The famous clutch restrictor removal mod. It's in the VFAQ. If you smell burning clutch after your run, you slipped it too much. You can be more aggresive with the 2100.
yeah thats all I do too, 5500 and drop the clutch... :thumb:
-Matt
Dumping the clutch is the best way at 5500. 1.7s are easily attainable. I got 1.80 outta my buddies stock tranny and stock clutch 2g. He had MBC, full exhaust and intake, AWD.
I'm netting 1.65s with my 2600 dumping a little higher.
