ACT 2900 Will NOT DISENGAGE
def042
Jun 1, 2005
college park, Georgia
Brand new clutch master cylinder, new slave cyl. New ACT 2900 pressure plate, street disk ACT street-lite flywheel. Clutch will not disengage. 1st gen.Any ideas on how to get working?
Clutch is adjusted all the way out. Transmission & Engine on dowel pins & bolted securely. Will go in gear & not disengage.
I had the same problem when I installed mine. It turns out that when the clutch over disengages(bear with me), the pressure plate goes back towards the flywheel engaging the clutch disc again. I put one wheel on the ground while a friend pressed the clutch pedal with the transmission in gear. I tried turning the hub and with the pedal about halfway down to the floor the clutch was disengaged. Once I adjusted the rod it worked great.
Dont the clutch forks have a problem with bending? Mine just straight broke off but maybe the 2900 just bent it a little.
