akdsm
- 59
- 0
- Jan 4, 2003
Chugiak,
Alaska
Just completed installing GT3065 and 44mm tial along with a Magnus intake and PLX 300 on 2g Talon with 6 bolt conversion. It idles fine, no sticking of throttle linkage, revs fine and returns to idle. On the road as boost starts to build it will just accellerate even if you take your foot off the pedel. Nearly like the cruise control is taking over and is set for 100+++. Once you step on the brake and clutch it will come down. Also, boost will go to 30 psi no matter where I set the boost controller. I have totally disconnected the cruise control cable and wiring, checked the vacumum hoses on the throttle body rechecked the throttle cable for any obstructions. Any ideas on what is going on would be great. Thanks.
-Ben
-Ben
