abs delete with 90 parts
danyz250f
631
6
Mar 13, 2005
Rexburg, Idaho
I have a 90 rst laser without abs, and I want to get rid of my abs. Can I use the parts from the 90 on my 92 or are the 90s different like everything else. I would probably follow the vfaq just use the old parts off my laser.
All you need is the proportioning valve from the non abs car. I just did the conversion. I unscrewed the lines at the abs pump, bent them, and threaded them into the proportioning valve. Then bled the brakes.....20 minutes total.
