A quick help needed.
casper_talon
86
Nov 29, 2006
Quebradillas, Puerto Rico, Central America
Also, how I can lean out my car a little bit. It's a non-turbo, but has headers, a ram-air intake, full 2.5" exhaust, blocked -egr and a turbo fuel pump. I've checked and it's mostly running rich, once it ran about half-stoich to a little less and the car pulled a lot better. Would I need a fuel press-regulator? change ign timming? Any help would be good!Thanks! P.S. I plan to run N20 maybe next month, shuld I leave it a little rich like it is?
I dont have much experience with no2 but.... Id imagine you can use an afc to accomplish your goals, however, I'm wondering if you have a wideband or a narrowband air/fuel sensor. If you dont have a wideband I would invest in one. Also id invest in some sort of knock sensor setup similar to the turbo cars. Especially if you plan on not blowing your car up anytime soon.
Id lay off the nos until you do some more research about it and learn how to properly setup your car for nos.
goodluck.
