98spydert
- 1,916
- 8
- Jan 16, 2004
Phoenix,
Arizona
Wow, give it a rest.
rarson said:If the tuning is adjusted to compensate for the change in airflow signal, I see no detrimental effect for modding the MAF in the way that Granatelli does.
It's clear that, from the experiences of other, that the GM MAF doesn't need the "straightening out" effect like the stock MAF does; after all, it is a hotwire MAF and not a Karman-vortex. Case closed on that one. And I don't think it's going to be filtering anything; the airfilter's got that one covered.
I'm not saying you're not making valid points, because there's some good stuff there, but there's more to it than what you said. Mike Licht, the creator of the translator, has provided flow numbers showing the increase of removing the screen and the restriction in the MAF ends. He even stated that removing the screen probably wouldn't hurt the accuracy of the MAF, either. I believe that info is in the NABR archives.
As already mentioned, I'm willing to bet that one reason it makes more power is because it sends less signal, therefore leaning out the A/F mixture.SummerWolf said:If you have more air moving around the sensor the computer has to compensate for that somehow, thats what I mean by that. It has to compensate by adjusting timing, fuel etc. does that make sense to you!?!?! And thats also why the MAF makes an S-10 go faster is because the computer compensates for the added airflow.
I can't agree more. Every time I check, my 5.0 has a leaf or two right in front of the screen. Useless? Far from it. Car companies usually don't spend money developing unnecessary products. It's not like they're out to lose money.boostedinaz said:The screen in the MAF does alot of things. The most important is the air flow but it also keep debris from killing the wires. I have seen a few times when a piece of filter or maybe just a small rock has found its way in the intake tract. That mesh kept not only the MAF alive but also the motor.
kpt4321 said:Sure, but how do you suggest that the tuning be adjusted? The MAFT doesn't have high enough resolution, necessarily, to work with a MAF with a totally different curve than the stock piece.
Unles you're editing the code on the ECU level, it's not going to happen. Even if you are, it's going to be a pain.
rarson said:I'm sure that good results could be had with DSMLink. I realize that's not an option for everyone though.
It's nice to see some actual tech information being discussed in this thread though.
