tim_korn_99
- 216
- 0
- Aug 3, 2004
Bentonville,
Arkansas
Well, here's the deal. EVOIII 16g, 3" exhaust, Intake, 550cc injectors, SAFCII, 255 walbro pump, bpr7es plugs, accell wires. 93 octane.
My car pretty much runs like crap compared to others with the same setup... I'm running 18psi, but it creeps a little higher during a long WOT pull. Normal accellerating at about 20% throttle is smooth up to around 2800 rpms, then it gets jerky til 4000 rpms, then its smooth again. Checked for boost leaks, found that the throttle body seals were leaking, so i replaced them. Also, my BOV was leaking at the base. I RTV'd that, but i'm not 100% sure it doesnt leak a little bit. Point is, the logs were the SAME BEFORE i fixed the boost leaks....
This is a 3rd gear pull.
RPM - Timing - O2
3244 8 .93
3404 -3 .93
3524 9 .93
3744 11 .93
4112 11 .93
4260 10 .95
4432 10 .95
4500 9 .95
4624 9 .97
4780 10 .95
4948 11 .95
5096 12 .95
5564 12 .95
5720 12 .95
6000 12 .95
6160 9 .95
6304 11 .95
as soon as i let off, rpms at 6152 and timing goes to 26.
I bet you are saying, add more fuel with the AFC, right? Well...... that's the best i could get it. I added more fuel. and the 02's were at .97 instead of .95, and timing was LOWER. I even added more, and then i could smell gas, and it sputtered from being too rich.
Any ideas here?
The car has never really been "smooth." Even when it was stock with the T25. It's always been kinda jerky throughout the RPMs. I dont think i can tune this out.
During the loggging runs, it feels sluggish, not like it should. You can definately feel it jerk when the ECU pulls timing real fast.
Thanks
-Tim
RPM - Timing - O2
3244 8 .93
3404 -3 .93
3524 9 .93
3744 11 .93
4112 11 .93
4260 10 .95
4432 10 .95
4500 9 .95
4624 9 .97
4780 10 .95
4948 11 .95
5096 12 .95
5564 12 .95
5720 12 .95
6000 12 .95
6160 9 .95
6304 11 .95
Any ideas here?
Thanks
-Tim
