Help with a log
FlaToUt-GST
116
Jun 14, 2002
Well i did some logs today, and since the 3' dp install i was getting creep to 17psi, and the knock to come with it (.88v o2's) So i turned the boost down to where it hits at 12, then creeps to 15 pretty quick then holds almost perfectly.
timing drops to 9* within 4200-5300 then...
5400 10*
5700 11*
5800 12*
5900 12*
6000 14*
6100 15*
6200 15*
6300 16*
6450 14*
6500 13*
6600 12*
6700 14*
6800 14*
mods: intake, full 3' exhaust, b16g, walbro 190, uicp etc..
Im guessing i got knock at 6400, but its only at 15psi, which i was able to run just fine when i didnt have the dp..could warmer weather contribute to knock at all, because it is warmer now then when i logged last. thnx in advance!
Well, i just did another run (much cooler outside) This time boost crept to just over 16 psi
5000 7*
gradual smooth surve to
6800 16*
I'm guessing the cooler weather helped eliminate the knock.
Also, which o2 sensor should i be logging? Thanks!
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
