slowstang
- 0
- Oct 24, 2007
Sebring,
Florida
Hey guys. Out of nowhere, my A/C compressor and A/C clutch quit getting power when the A/C is turned on. So I checked the two silver relays that control them (in fuse box close to driver side firewall). I found the problem to be that the voltage across the two pins that switch the relays on is only 9.5volts which is not enough to flip the relay switch. I checked the relays at 12volts in another slot (radiator fan slot) and they both worked fine. Likewise if I use a jumper wire to simulate the relay both the AC fan and clutch will work. What could have happened that all of the sudden the voltage going to that relay would drop by ~3volts?
