A/C clutch went out
Deuce_three
451
5
Jul 9, 2008
Lynnwood, Washington
So my A/C clutch went out and I probably won't be replacing it until this summer. Is the A/C a vital component everyone should have or should I just remove it and roll down the windows this summer?
all depends on your opinion, i use mine in the winter to dethaw the inside of my windows, and use it a ton in the summer... depends on where you live and what your preferences are
I tested the AC again and it works fine. Apparently, the only bad thing is that the Compressor clutch bearing went out, causing my car to sound like a failing Harmonic Balancer.
I know where to buy a new bearing. My question is if I need any special tools to remove the old bearing?
