98 gsx have a/f gauge, ecumenical throwing code p0135
Freemanke
Sep 18, 2014
Port Orchard, Washington
Bought this car awhile back. Have not touched it performance wise. I was driving the other day and I started to notice my a/f gage was lightly hinting in the red zone, pegged low lean. After a bit more driving, it pegged low lean bright red and check engine light came on. When I got home, I put the scanner on it and got back p0135. Here's my question: does having the a/f gauge mean I have a wideband? I'm not sure. I noticed the o2 sensor at the bottom of the manifold. But I'm not entirely sure how that gauge gets a signal. The cars definitely running in limp mode. The exhaust smells like an 8th grade bon fire :) I wont leave this problem. However, if my options are $300 mitsubishi o2 sensor OR pay the extra for dsmlink and hook everything up the right way, I think it might be time to drive old whitey for a bit
A code P0135 may mean that one or more of the following has happened: O2 Heater element resistance is high Internal short or open in the heater element O2 heater circuit wiring high resistance open or short to ground in the wiring harness
Read more at: http://www.obd-codes.com/p0135
Copyright © OBD-Codes.com
I would see if it is a 2-3-4 wire 02 sensor and get the same type aftermarket and all that,s different is no OEM plug so hack it off ur old one and its very simple wiring. If a heated 02 sensor will have more wires etc. If you want OEM I can try find you alot cheaper and new.
You can find numerous OEM o2 sensors for like 40-80 dollars, straight plug in too, you can find them on amazon. Bosch, denso, good brands no knock off names
So I kinda jiggled the wires that come from the gauge and obviously slice into the original cable run.....no lean readings. Stoic like I want it. I'm in my way to radio shack to get some connectors and heat shrink. Deleted the code too and hasn't come back in yet. My votes on a short but I'll know for sure once I remove the electrical tape. God bless the half-ass DIY installer guy. Reeeeeal man of geeeenius.
