ECUflash 98 GST Logging with EVOSCAN
Redlinegvr4
Aug 10, 2004
Riverview, Florida
All,
I need some help, I am helping a friend with a 98 GST. When driving the car any time it starts to build boost it just pulls all the timing. I keep seeing in evo scan that the MAP sensor is maxing out at 46.24 psi which is 100% wrong as it is only showing stock boost on the boost gauge i put into the car. The only thing i can think of is the logging definitions are wrong. In evoscan there are multiple options for logging, which should i be using to log a 2g?
Thank you.
