98 Eclipse GS Turbo for sale/part out, lots of updrades
daj2006
Jun 4, 2006
Hazel Green, Alabama
Everything on the car works great and is for sale. The car is in great shape and has been in the garage the majority of the time. I don't want to sell, but now that I have two children, I have other priorities in my life. The body has about 60k miles on it, and the motor about 1500 miles. The car is currently registered in Alabama with a clear title. The majority of the performance modifications were installed with the motor. The car was previously sponsored by Stillen and Kicker. I hope to get lots of interest. Thanks for your time.
Modifications
• Slowboy Racing 420a Block
o Wiseco 8.8:1
o Crower Rods
o Clevite Rod Bearings
o Clevite Main Bearings
o ARP Rod Bolts
o ARP Main Bolts
o Bored .020 over
o Decked Block
• Slowboy Racing Stage III Head
o ARP Head Studs
o Cometic Head Gasket
o Crower Stage II Turbo Cams
o AEM Tru Time Cam Gears
o Crower Springs
o Crower Titanium Retainers
o New Valve Stems
o Supertech Valves
o New Valve Guides
o SBR 5 Angle Competition Valve Job
o SBR Stage III Port Work
o 100% Hot Tanked
o Pressure Checked
o Fully Decked Head Surface
o Candy Ruby Red Valve Cover
o New Mechanical Tensioner
o New Gates Racing Timing Belt
o Custom Intake Manifold and Throttle Cable
Turbo & Intercooler
• Garrett GT 35R Dual Ball Bearing Turbo
o Oil and Water Cooled
• Hahn Racecraft Front Mount Intercooler w/Piping Kit
• TurboSmart 38mm Wastegate
Ignition
• Custom Coil on Plug Setup
• Magnecor Race Plug wires
Fuel
• Walbro 255 Hp Inline Fuel Pump
• FAST 95 lb/hr Fuel Injectors
• Ross Machine Racing Fuel Rail
• Aeromotive Fuel Pressure Regulator
• Numerous AN Fittings and Starlite Racing Hose
Cooling
• Fluidyne Aluminum Radiator
Exhaust
• Custom 3” Downpipe
• Star Exhaust Manifold
• Magnaflow Custom Exhaust
Drivetrain
• Competition Clutch Stage 4, 6 Puck Disk
• Competition Clutch Stainless Steel Flywheel
• ARP Flywheel Bolts
Electronics
• Haltech Ell V2 Standalone ECU
• Custom Haltech Hall Effect Sensor
• Haltech Boost Control Solenoid
• RacePack Digital Dash Display
• Haltech Wideband O2 Sensor
• Autometer Guages
o Fuel Level
o Oil Pressure
o Exhaust Gas Temperature
• Greddy Turbo Timer
• Custom Wire Tuck
• Custom Military Spec Connectors
Interior
• Custom Seats
• Custom Speaker Box
• Custom Door Panels
• Short Throw Shifter
Audio
• Alpine iDA-X001
• Alpine 6.5 Inch Component Speaker Front and Rear
• Alpine MRP-850 Mono Amplifier
• Alpine MRP-450 4 Channel Amplifier
• Alpine Type R 12” Subwoofer
• FatMat Sound Dampening Mat
• Summit Custom Battery Box
Wheels/Brakes & Suspension
• Volk RE30 Racing Wheels
o 18 x 8.5 Bronze
• Falken Azenis RT-615 Tires
• Stillen AP Racing 4 Piston Caliper Brakes
• Cross Drilled and Slotted Rotors
• Megan Racing Coilovers
• Stillen Strut Tower Braces Front and Rear
• Energy Suspension Master Urethane Bushing Kit
Pictures located at: Out and About - Huntsville Car Scene.com
Currently the website is under going maintenance, so if you need pictures email me at [email protected]
David Mathis
WOW! I really hope you can sell the whole car because thats a FIRE setup! If you start to part it out i could really use some of the parts. Walbro 255 Hp Inline Fuel Pump
