97 Talon upgrades on a 95 Talon? easy to do?
4TireFire
Nov 22, 2003
I have a 95 Talon TSI and prefer the look of the newer 97 styly bumper cover and raised rear spoiler. Will these just bolt on my car or does per say the front cover require a different inner support ect. Mine is torn and needs to be replaced anyway.
thanks
All talons use the 95-96 Eclipse headlights so you can put the 97 Talon front bumper on the 95 Talon. Good luck trying to find a high rise spoiler off a 97-98 Talon.
as said ^.
a 97-98 bumper will fit right in. you may want to consider getting the stock fogs for the entire conversion.
the high rise is few and far between and DOES not bolt up to stock location. you will have to cover up your stock holes when you switch.
keep in mind that you won't have the cool side strakes we have :tease:
Hmmm, actually he would have the side strikes..........but only on the rear bumper, not the doors.
I was going to do that conversion on my 95 tsi, went with a 2gb eclipse...........mmm good :sneaky:
I appreciate all the info. Just one more question,, Can the side strikes for the door and rear quarter panel be purchased from the dealer and installed on my 95? or is the door different...
thanks for everything!
yes you can purchase them, like any other factory part. you just have to PRECISELY drill for the tabs in the back when installing them :thumb:
kg- yea you're right LOL.. it was late when I posted that :D
You'll need to drill 4 holes on the door and 2 on the rear fender. I took them off mine and trashed them cause I thought they were ugly. If I knew someone wanted them I would have kept it.
i just went for the full conversion to 99 eclipse. i think it just looks better :talon: / :dsm:
yes the 97-99 kits look better but i don't have trouble with scrubbing the ground or my side shirts coming off. i had a 98 gst before i know the struggle of the body kit :( , now i have a 96 tsi and no more worrying. :thumb: ta :talon: lon
IF I go from a 95 eclipse to a 97-99 body I will have to replace my headlights as well, right???
my side skirts have never come off, and i take my car offroading so much hitting piles of sand going 50..
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
