97 gsx dsmlink
Roope5
Jun 12, 2013
Mt home, Idaho
Looking for dsmlink in an ecu as soon as possible and see them on here but does it matter what year of ecu it comes from?
Someone just told me I would have to change firing order. True? And how would you do that?
No, you just check in the box under invert cas and your good to go.
Please stop giving incorrect information. Read this:
swapplugwires [ECMTuning - wiki]
2G Plug Wire Swap and CAS Inversion Details
When installing a '95 EPROM ECU (or '96) on car with a non-'95/'96 style cam angle sensor, you have to rearrange the plug wires. You will also want to check the "Use non-95/96 style cam angle sensor" checkbox in the Misc tab of the ECU Config tab (called "Invert CAS" option in the ECU→Miscellaneous dialog in the older V2 application).
When installing a '97 ECU that has been converted to EPROM on a car with a 1g or 2gb cam angle sensor, you would not need check the box to invert the CAS and swap plug wires, as the signals should be the same as the ECU is expecting to see. However, if you are installing it in a car with a '95/'96 cam angle sensor, you do need to check the box to invert the CAS, as well as swap the plug wires.
If you don't know whether you have a '95/'96 style cam angle sensor or not, check the passenger side of the valve cover for an externally mounted cam angle sensor. If one is present, you'll see it installed in the area shown below
I'm using 95 ecu with EPROM and dsmlink in my 97. I need to do wire swap and the CAS thing?
Does auto or 5speed matter?
Ok awesome help thanks so much now to find me an ecu with dsmlink since most everyone is 1g or there sold.
