97 crank, pistons, rods in 91 block
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
Can it be done? I have a bare 6 bolt 91 block which I want to build up now. I have forged internals from a 1997 gsx with only 3500 miles on it ( rings didn't seat and I got a new head so motor needs to be torn down anyways ) .. can I jsut swap all the internals inluding the crank into a 6 bolt block? The reason I don't want to use the crank off of the 6 bolt is because the eagle rods are 2g rods which I don't think can be installed onto a 1g crank. Thanks.
7 bolt internals will not work in a 6-bolt motor. 7 bolt crank will not swap into a 6-bolt block.
srry man
