'96 talon compared to a '93
Status
Not open for further replies.
scaryc
54
Sep 6, 2004
warren, Ohio
would a stock 96 talon n/a be much faster than my stock 93 n/a? both are 5 speed. a friend of mine is buying a 96 talon and he says the car beat a friends v6 eclipse. well, this friend of mine is getting all worked up and saying his talon is going to be faster than mine. what should i expect?
If you have an n/a 2.0 liter, it should be a drivers race stock for stock. If you have the 1.8L n/a motor, it'll be even for a little while until the little engine runs out of torque. And to beat a V6 eclipse, his car should be running in the high 14 second range, which I highly doubt...
he says since his engine is newer his car will be faster. . .. we will both have the same engine btw
Technically, he is right. SInce his engine is newer, as long as both engines were taken care of equally well, his will have less blowby (ie - better compression)
Actually no you won't... he'll have a 420a chrysler motor (similar to DOHC Neon) and you'll have the 4g63.Assuming both cars are five speed it should be a close race....all 16 1/2 seconds of it.. :)
Status
