96 gst mods.
willye_br
92
Jun 9, 2009
boston, Massachusetts
hey im new to dsm and my goal is around 260-280 hp. what are bolt on parts i can get to improve hp? heres my ideas feel free to give your opinion .Also i dont want to upgrade the turbo T25 yet.I have intake pipe and filter.fuel pump 255 walbro.
Heres my ideas.
3"catback exhaust
exhaust manifold (tubular type) can i just install it or i need to upgrade something?
550cc injectors
fuel Pressure regulator
Front Mount intercooler
I dont want to jump from now to 280hp . my goal is that but i want to know good bolt on parts that i can get so that later on ill reach 280 .
Thanks :thumb:
sorry i searched and found that the vfaq on this website shows everything.i need help tho
t25 on 15psi..
3"catback or 2.5" better?
the tubular manifold? just bolt on to t25 and car should be a little better or whats needed?
o2 sensor housing. just bolt right on it too?
Anytime you alter the fuel injectors or fuel system. It is mandatory to tune the car with a maft, piggyback or standalone ecu so you are not running off the wall fuel maps. For the price of a new Safc save up 200 more and you can buy dsmlink and do soooo much more...
only thing i replaced was fuel pump 255 walbro
450cc injectors are good untill what hp?
If you get a 255 fuel pump you need the AFPR. When you get your 550cc injectors you MUST have some way to tune fuel. I suggest DSMaps/Jackal for the cheaparse and Link for the average DSMer. Anything more than link is above my head, I really don't know a whole lot about link yet, I know it makes me hot and bothered.
Anyways, you can get away with stock fuel for a while. If you havent put on the 255 yet, wait until you can install the AFPR as well. Then wait until you can tune fuel before installing larger injectors.
Some mods are like PB&J. Cant have one without the other.
Manual Boost Controller and Boost Gauge
FPR and 255 LPH or bigger
Turbo and Wastegate
Injectors and Tuning Device
so on and so forth.
well i installed the 255 already about 6 months ago the car runs fine . The wastegate on the t25 is a 15Lb wastegate made my FORCED PERFORMANCE. my boost is around 15-14PSI.injectors are stock 450cc.intake pipe and filter and a muffler not catback. do i need the AFPR? and the $40 ebay ones work or should i get a brand name one?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
