MelissaO
- 0
- Mar 24, 2014
New Orleans,
Louisiana
Hey All,
I have a 94 talon, 2.0 esi. It was my sister's for a while and she's the type to say "it's a transmission problem!!" and after careful examination you say "no, it needs gas" so it has not been well maintained. I am having trouble getting it up and running. It's been sitting for a while, I put in a new clutch and clutch slave cylinder (the master looks new), put it back together and it won't turn on. The starter would kick out and spin and the engine would TRY but would not turn over. I tried starter fluid in the intake and making sure all connections/fuses etc. were good and realized the bell housing ground was not connected to the - battery end. I connected it, and now you can hear the metallic click of the starter kick out, but nothing else. I went to a local mechanic who gave me the ignition wiring diagram and I don't understand it b/c
1. Says that the thermostat housing is grounded to the - bat instead of the transmission being grounded to the - side of battery. However the wiring from the thermostat is in the harness and looks like it goes to the + side of bat. Plus I can't see where else the transmission ground would go.
2. Says there is a 80amp fuse in the engine compartment relay box (I think it's for the alternator) however on my vehicle there is no 80am fuse on the map or in the fuse box.
Maybe the body is 94 and the engine/wiring is another year?
If anyone has the wiring diagrams for a 93 or a 95 so I can check I would love to see them.
I am an amateur and barely understand what I'm doing, any advice would be awesome.
thanks, melissa
thanks, melissa
