92 eagle talon auto/manual
My 1G auto ran a 15.69 @90 with stock boost and leaving like a gramma because of traction, every run I got a little faster as I learned to launch it. An AWD auto should run easy 15.0 with just the boost turned up and running right. Crossfire's run 15.1 @ 93. Full Test: 2004 Chrysler Crossfire
Exhaust, cold air intake, more fuel and your gone. :hellyeah:
I've done a little bit of research on the DSM auto,and it is apparently a beast.
BTW, 1G auto's use the 13g turbo. Quick spooler but not much up top.
so can i ask what would i need to run a 16g turbo at 20psi that means engine upgrades and tranny
2G Maf
At least 550cc injectors
At Least a Walbro 190
Wideband AF gauge or EGT if you have the money
Datalogger
Intake
Exhaust
A form of tuning: SAFC, MAFT, DSMlink, Eprom chips,etc.
The stock engine is plenty capable of handling a 16G, so is the trans. I'd replace the clutch once it starts to slip under boost - which won't take long. So at least a "stage 1" clutch.
Like I said though - best to maintain it before you go spending all this money on mods before the car is even reliable.
Although other members said "search" I gave you a get out of jail free car on this research but we do ask that you search before you start a new thread on a topic that has more then likely been asked.
For example: Can you vent your stock BOV on the stock MAF : The answer is NO. Search BOV venting.
