91 transmission up into a 2gb with 7 bolt
The 1g transmissions don't have a place for the motor mounts. On a 1g the front/rear mounts are on the block on a 2g they are on the trans. I think its possible to swap the 2g bell housing but you will have to disassemble the whole trans to do that and you will also need a 1g or 2ga transfer case.
