91 Talon project
packinkimber45
378
3
May 26, 2006
Boise, Idaho
I thought I would post a log of my talon and it's work in progress. I bought the car in april of last year. When I bought the car I was told that since it had poly urethane motor mounts that was the reason the car shook really bad, which was hard to believe but I never had poly mounts on a car before so I didn't know any better. After driving it for a month I found out the balance shaft was out of phase. A friend of mine helped redo the timing in the car and get the oil pump in phase. After doing that and seeing how low my oil pressure was I decided to park the car and do some maintenance on the car and started ordering parts for it. It took a while of being lazy and contemplating before I started to work on the car.
The following parts that are going in the car:
Oem Timing belt
Auto tensioner
Idler pulley
Tensioner pulley
Oil pump sprocket
Balance shaft elimination kit
New oem front case/oil pump
Front and rear main seals
Main timing belt cover
Transfer case yoke seal
Properly functioning fiav off of my 94 non turbo eclipse (suspect for it's idle issues)
90 style oil cooler housing
B&M oil cooler
Stainless steel braided lines with ?an fittings
New starter plate and flywheel cover plate
Main bearings and rod bearing (once I figure out what I need to do in order to replace them. Lol.)
Knock sensor
1g black cas
Socketed eprom ecu
Autometer electric oil pressure gauge
Zaklee cam gears cover
I also tore out the old leather interior that was all torn up and replaced it with the non leather seats and door trims that were in mint condition from my 94 eclipse. The goal is to have it running the next week or two and finally driving it daily. Future mods plans are:
DSMlink
750cc fic injectors
Walbro 190 fuel pump
Different FMIC
EGT gauge
Wide band
4 bolt rear end
Mbc
O2 housing with an open dump
Lowering springs
Take off the ### two tone paint that has red glitters!
Mods currently on the car
Slowboy racing stage 2 race head with SI valves
ACT 2600
Evo 3 16g
Evo 3 manifold
Poly urethane mounts
VRS turbo back exhaust
Evo 8 fmic
Koyo aluminum radiator
Autometer boost gauge
Blitz full auto turbo timer
When I first bought the car and after taking off the stock rims and tires.
Started to work on it.
Motor is out finally!
This is my first time doing repairs of these nature, hopefully everything will be put together right. Lol.
Very Nice :D
That is one clean looking DSM! I love how "a little maintanence turns into a full rebuild"
HAHA....that's a DSM for ya! Sounds like a great build man, what kind of numbers are you looking for?
that is a super clean dsm! i wish my cars paint was that nice! it might just inspire me to spend the extra money on new paint.....then again i could always use a bigger intercooler....:D
Thanks guys. I actually want to redo the top paint on the car, it is black when not under light. However under the sun it is purpleish with red metalic flakes which I think is really ugly.
Got some more work done. An fittings on the oil housing, new oil pressure switch, and the autometer sending unit. Ready to go on the front case.
Ported the oil relieve valve hole to ensure my oil pressure doesnt get too high from eliminating the balance shafts.
Cleaned off all the old gaskets ready for front case and water pump.
Old interior.
New interior.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
