1G 91 Laser LED Headlight Conversion
AtomicSK
3
May 2, 2026
Portage la Prairie, MB, Canada
Hey guys! I was just wondering if anyone had suggestions for LED headlight conversions? I want to keep the pop-ups, but I can't see anything with the halogens
You can use the Holley retrobrights as we I got my friend to use them and they work well! He loves being able to see now.
Wiring took a bit as his were converted to H4 from importing into the UK but after some work they got fitted and super happy with them and look like stock which he wanted more than anything since it is a full stock car.
Good lights to opt for
So would they just plug in on a stock harness?
No. You need the reverse polarity connectors and wire them in and possibly do some wire adjustments depending how the harness comes in. Generally that is the tricky part and the rest is easy (apart from removing old mounting hardware)
