bmxfelon420
- 652
- 62
- Sep 6, 2005
Napoleon,
Ohio
Hey all, I am running a 91 CAS with the RRE adapter in my 2g. I am getting the random misfire code and my #1 injector stops firing. I researched that particular issue on here and found that the solution is to disable the random misfire detection, as apparently that is caused by the CAS being less accurate than the ECU expects.
My question with this is if I am losing the advantage of the misfire detection itself by disabling it? Can the car still detect actual misfires if they happen? I just want to make sure that I have as much safety as possible. One thing I did consider was swapping to a 94 cas and hooking my Crank sensor back up.
I guess the biggest question I have is what is the best way to go here? Disable the random misfire detection and roll on with the 91 CAS, or change the setup in some way?
