90 Plymouth Laser Turbo
XvErwinvX
May 29, 2010
Sioux City, Iowa
Looking to fix up my car this winter. Not exactly sure what I should do for a turbo. What type do i need that wont require additional work like forging and stuff?
This is easy make it stock and not worry about other stuff til thats done, look at the upgrade path on the site under tech. Thats a great way to start, get to searching.
If you wanted to go a little bit bigger the look for a Evo I-III 16g turbo. I know a couple of people running them on their stock internals and everythings fine. Defiinitely spoils up a lot quicker. Would recommend new fuel pump. Walbro 255 would be all that you need.
A Wally 255 is too much for stock 450 injectors. A Wally 190 is more compatible if you need a new one. Otherwise, if you're planning on staying with 450's, keep the stock pump intact in the tank.
I have a B16G in my setup and it scoots pretty quick with stock internals.
Good luck-DSM
