90 laser shell swap
Bmxnitro
Dec 8, 2015
petersburg, Michigan
Is it possable to swap the drive train out of a 90 laser rs onto a 92 to 94 gsx shell? If yeah what would i need to do it
swaps only work fwd to fwd, awd to awd, all 1st gen dsm's share the exact same chassis to basically a T. The only differences are the AWD chassis have a different trunk pan and rear suspension setup.
To do it you need tools..... almost every bolt will be either a 10mm, 12mm, 14mm, 17mm, 19mm the axel nuts are 34mm, if you have all those sockets and wrenches then your' set for taking the complete car apart. The only other stuff you need is 4 jack stands, a jack and a few screw drivers.
Sorry read that wrong, my answer was incorrect, missed the drive tran part LOL
