1G 90/91+ throttle body differences
Blam
186
May 26, 2003
Edmonton,
I read ALL 20-some pages on a search for key word "throttle" so dont say I didnt try LOL
turbo and N/T are the same.
1990
- the odd year
- larger TPS
- ISC with extended harness
- nipples are different
91-94 are all the same.
a 90 CANNOT be put on a 91-94.
a 91-94 CAN be put on a 90 but has to use 90 sensors (I think I am wrong here)
91-94 can be put on 2g dsms with slight modding
http://www.roadraceengineering.com/2gtbswap.htm
where am I wrong?
or can a 90 use 91-94 with ANY sensors?
from what I understand 90 TB is sensor specific so you have to use 90 model sensors and really isnt worth it I also have read that the 90 isnt 58-60mm its smaller so. the 91-94 are the good ones and can use the 95etc sensors. I have a 91-94 on my car and used all the 2G sensors.
mitch
TPS on the 91-94 is the same.
95+ has to be used on whatever TB you have.
91-94 TPS cannot be used on a 90
91-98 ISC can all be interchanged
only 90 ISC will work with a 90?
someone else has to know this stuff
correct me if I am wrong anywhere
does anyon eknow if a 91-94 TB will fit a 90?
do you have to use the 90 TPS? and the 91-94 ICS will work?
I just want to add that the N/A and Turbo TB's arent the same. 91-94 are 60mm, but do not use the 4 bolts to attach the upper IC pipe. You would need a 2-1/2" coupler. They also do not have the butterfly shaft seals.
